where is the maf on my c class w203
housewinnie
can anyone tell me where it is and if i can replace it myself? cheers
What model 203 do you have
H
housewinnie
02 c270 cdi cheers...its just been serviced and i did point out this acceleration problem but its just done it again on me and i just want to know if i can take it off and clean it and then put it back...
theboynextdoor
hi all a newbie here. Iv had similar problems with revs and accelaration and was told its the MAF (diagnostic computer stated). Iv read on the forum and price varied from 50 (ecp) to 300, also I have seen the diagram someone posted of where the MAF is located but I cant make out anything from it! could someone please perhaps give me a bit more info on how to locate and replace? thanks
p.s 2002 c220 is the one I have, (saloon) i assume its a w203.
Cole@MBS
www.mbssouthampton.co.uk
In bewteen the airbox and intake line. 5 pin mutiplug.
Welcome to the forums
theboynextdoor
thanks a lot. 5 pin multiplug - is that the screws on it? Also would i just require a sensor or a whole new meter?
Cole@MBS
new sensor needed, five bit torx set needed also to remove the screws!
The sensor bit cost on average £57 from any Bosch service center
theboynextdoor
thanks sam/unit sorry if I sound a bit silly. Im a complete novice at it, I opened the bonnet and to be honest am totally confused, so may just end up taking it to a garage :(, looking at the engine would I have to remove any covers etc to get to it?
Cole@MBS
Open bonnet, look to the left of the engine, theres a long black box along the side of the engine, at the front of that long box is a sensor with a muti-plug going to it, thats the sensor you need to replace!!!
Cole@MBS
Tried for 5 mins to find that link Malc, gave up!! i must be overworked, yes, that sounds like a good excuse!!
With fire fox scroll down,,its perfect, its so good you can even smell the fuel on it :D;)
theboynextdoor
hi all thanks t Sam and television for their input. managed to change the sensor (part from ecp) and its still causing a problem as before. Any suggestions on what else could it be? The diagnostic computer had MAF fault so I thought this would have done it?
