Wheres the atf fluid go
eddiereilly
WHERES THE TRANSMISSION FLUID GO ON A W203 C240 AND A W203 C32 AMG ,
just checked mine this morning sems very low , had the cars on ramps and on my c240 theres abit fluid on the pan well a fair stain ,that would cause my gears to slip wouldnt it , the fluid is a redy colour is that ok ,i dont feel any different as to when im driving but was told by the star i had slippy gears , so best do it i think and get my new c32 done at same time
so wheres it go and what level should it be and colour when i take out
In the same tube you put the dip stick into this morning! use a tube otherwise it will go everywhere!!
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Neither of your cars have a dipstick for the ATF fitted to the vehicle, all you have is a dipstick tube (possibly with a sealing cap on top) fitted to the rear of the engine on the drivers side, you need to buy a dipstick from MB, if neither of your vehicles show in their history as having a gearbox fluid and filter change, get it done and this will improve the gear changes and prolong the life of the gearbox and torque converter.
I personnally would only use genuine MB ATF
LYNALL
Kent
You can use the flexi curtian rod as a dipstick as it goes right to the bottom of the pan so you measure up the stick, engine has to be running in park either hot or cold, bottom 2 marks are cold measurement points and top 2 are hot points.
Lynall
Zebra
Yorkshire
C220CDI
ATF and engine oil dipstick
Hi Lynall
Don't suppose you have made a dipstick to measure the engine oil level, have you?
Hi Lynall
Some one has,do you have a dip stick tube fitted
Alcudia
S500 Coup Black, S280 Gold(ish)
Hi
Ive made one - get 1m of flexi spiral curtain rod.
Take the outer white plastic of the bottom 100mm and file marks into the dark gray steel at:
8mm & 19mm
54mm and 66mm
This will give you the "cold" and "hot" reading marks. If you dont take off the plastic the oil is so thin (well it should be) that its almost impossible to see the level.
Ive tested this against a proper MB one and the reading is accurate!!
Here we are talking about engine and trans dip sticks :confused:
Zebra
Yorkshire
C220CDI
Malcolm
The car does have a dipstick tube fitted for the engine oil.
Dipstick from MB is £64 + VAT so wondered if someone has made one for measuring the engine oil.
Jim turk
New Registration
Canada
c240 2001
Hello sir ,
I have a mercedes c240 2001 with 140,000klm , the transmission went on neutral while driving by it self , i have tuned the car of and on then went back normally , the the engine light went on
i wnet to a garge they have reseted the engine code for me , the car went fine for about 20 min then the problem came back, could you please help me with that.
thanks
lwbnick
wales
euromerc.tumblr.com
expedition
Hello sir ,
thanks
A trip back to the garage is in order.
www.ckinsurance.co.uk
