Which AUTO BOX DO I HAVE FITTED
Hi i asked on this forum about changing the auto gearbox oil on my 1998 C Class 250 TD and was directed to a thread We Did the atf change on 1997 W210 and what a good write up this is and great pictures. My concerns are is my gear box a 722.6 using the special synthetic oil or does it have the ordinary atf oil in and how do i tell. regards Bob.
In the engine section I have the list of oil gearbox fluids and the capacity, it is ATF all type possible to use are in the list
BlackC55
South coast
C43
BTW it is a 722.6 box you have withthe s/w switch on the selectore module
Ellsy Tanners
Mars
The electric atf fluid can be used in both 722.6 and 722.5, mercs only generaly supply the later type oil if you by it from them.
722.9 is a different oil and that alone must only be used.
R
Hi thanks for the quick reply Blackc55 yes i have the ws switch by the gear stick. does that mean it uses the fully synthetic oil ? Only the garage that has changed the oil for me today have put atf in i have been back to see them because they told me they only replaced what came out 3.3 ltrs so they havn't drained the torque converter so they told me to bring the car back on friday and they will drain it. My concern is have they also put the wrong oil in.
Ellsy Tanners
Mars
Most 722.6 boxes dont have drain plugs in the torque converter, so they may have a job on there hands.
The drain plug was dropped in 1998-9 so there is a good chance that yours has the drain plug, the only snag now is that the old fluid is now mixed up with the new, so that cant be done without a complete change again
http://forums.mercedesclub.org.uk/showthread.php?t=25558
the link shows how much fluid comes out and goes in, also the type
R
Hi Malcolm thank you for your reply well all i hope is there is a drain bung on the converter so they can drain the lot out if there is no drain bung how will they get the oil out of the torque converter this is tutning into my worst nightmare. regards Bob.
Dont let it upset you. I have heard it said the it can be pumped through the cooler, but this is not necessary. Most it gets changed from the box itself, we are all in the same boat and after 99 no one can change it, by doing the change every 40k miles you have nothing to worry about
R
Hi Malcom i went back to the garage today to see what oil they did put into the gearbox. I have come away happier as they have used a compatible oil. I took with me a printed copy of the oil change with pictures that Parrot of Doom had posted they say that they didn't realise that you could drain the torque converter. So there having the car back in and will drain the sump and the torque converter and replace with new oil. thanks to everyone for their help regards Bob.
