Which engine oil?? c200 cdi
h9llw
Hi guys, what engine oil should i use in my 2005 c200 cdi?? gonna be changing soon and would like to use correct stuff,wil it be ok on 10/40 castrol gtx or should it be fully synthetic?? cheers for the help.
lulu
Kingsbere
Have a look in your manual. It should specifiy a standard such as 229.1, 229.3 or 229.5. If you've got a DPF you'll need something like 229.31 or 229.51. Castrol GTX is only 229.1 and is the cheapest grade suitable. You'll be able to have a longer service interval if you use a superior grade oil. (Make sure you set ASSYST correctly)
Xtractorfan
S class
Check out many of the oil company websites, you can pump in your reg no and they will give you the correct grade of oil to use..
