Which is the original finish for my 124 cab wheels?
mtinlin
Woking
E320 Cabriolet, 300TE 24v, E230, Subaru Legacy Estate
I must get these wheels refurbed. The car is new to me and I notice that I have three wheels with what appears to be a 'metalic' finish and one in plain silver. Numerically, I guess the 'metalic' ones are correct but can someone confirm this please? The car is a 1993 pre-facelift with Sportline. I have attached an image of each of the two different wheels (I hope).
Thanks for your advice.
I am sure that they should be brilliant silver, most wheels are
stats007
Hampshire
Looking
From memory they're Astral Silver which is a flat silver with some yellow, blue and black tints. Most refurbishers will just paint them a fine silver - the metallic flake should be very subtle.
kth286
E320 Coupe 95
mtinlin
You should have 5 x B6 6 47 0086 7x15 et 41 HIGH SHEEN.
mtinlin
Woking
Ah ha! That sounds like the answer. They do have a machined look. I have not removed them to check the width. I thought that they were 7.5 wide as part of the Sportline pack.
Thanks David.
stats007
Hampshire
Looking
The wheel is painted first and then the face machined and lacquered. As you can see by the corrosion, machined wheels don't last very long hence the odd wheel has been painted.
