Which Oil for my W211 E320cdi
AnthUK
Due for oil change on my trusty E320. Can I use 5w- 30 synthetic Texaco Halvoline. Handbook not much use
BlackC55
South coast
C43
A fully synthetic oil is best like Mobil 1 or Castrol edge sport. Look for the numbers 229.5 or 299.51 on the can.
Warrio_blue
London
E320cdi L6
Benz e320cdi w211
Quick question black c55,i've got the w211 e320cdi currently done 120k,its an 03plate due for oil change,what would be the right oil for that sort of mileage? and how do i reset the clock as it shows 1000 miles to service after i change the oil,cheers :)
S500 Pete
Essex
S500 (W222) 2014. Turbo 4.7 V8 with loads of toys. Superfast luxury.
ASDA have some good deals on Castrol Edge, about £30 for 4 litres
S.Speed
Lancashire
Older Citroen Now :-(
My W211 E320 really ran very, very smoothly on the Castrol edge oil.. It actually ran better on the Castrol than it dod on whatever MB used !!
On a slighltly different subject my B 180 Cdi runs far smoother on Millers oil than it does on the MB stuff..
I have always loved the Millers oil for diesels..:D
N
npuk
Will be in your owners guide. Any oil that meets 229.31 or 229.51 is for cars with DPF.
Dazzler
Haverhill, Suffolk
W211 E320 CDi Estate 05
Its just some are 0w and some are 5w but none seem to say low ash so I was getting a little confused?
carabind
Lancashire
e class
This may help the OP - you can search for your car and it will give recommendations:
http://www.opieoils.co.uk/c-716-mercedes-engine-oil.aspx
Looks like 5W30W is what yoyu are looking for, something with a wider range (ie 0-30 or 5-40) will help in either very cold(former) or hot(latter) weather
But for the UK, you should be fine with 5-30.
www.W140.co.uk&www.r129.co
