Which petrol should I put in my CLK 200 Kompressor?
R8Chris
CLK 200 AMG Sport Cabriolet
Just looking for some opinions on which fuel I should be using. Is there any benefit to filling up with the higher Ron fuels. I am getting 28-30mpg on daily use and wondered if I could improve it by changing fuel.
Regards Chris
95 I reckon , it's the same engine as mine . have a look inside the filler cap , if it's meant to take 98 it will say so .
R
R8Chris
It just says 95 but I wandered if using a better fuel would have any benefits. What mpg do you get?
95 it is then , the cost difference will offset any improved mpg (but I doubt you will get any with 98 ) .
About 30mpg on general stuff , up to 36 on a run with the roof up at 70mph , this is on 17 " wheels.
This is the trip computer from a drive to southern Spain this September .
R
R8Chris
I will stick to 95 then. Which gearbox setting do you use day to day. Is there any difference?
It is mainly used by Mrs W in C mode , I always stick it in sport unless I'm on a motorway and just in cruise . No real difference in mpg . C starts in second gear , S starts in first and holds the revs for longer before changing up .
R
R8Chris
So C would be best for wetter weather and S for smile on the face . Thank again for the info, much appreciated.
If chasing economy then C may give a few extra mpg. Frankly I'd just use whichever feels nicest for what you want to do.
As above 98 in a car designed and mapped to use 95 won't give any significant benefit. The way the ECU works is it starts with timing at a given value then retards it. If you want to get the best from 98 you need more advance on the timing.
John Laidlaw
Wirral
Land Rover Discovery 4
Not many really need above 95 to be noticeably different and even then...
I experimented with 99 momentum from Tesco which is the only 99 near me, 98 shell , 97 BP and Sainsbury’s 97 and from them all the one which seems to work best is Sainsbury’s! It’s also the cheapest strangely
Ok not very scientific as I haven’t done track timing nor dyno checks with each just purely feel, but I am quite sensitive to how my engine runs
R
R8Chris
Thank you for the advice. I'm having way too much fun and enjoying driving again. S mode doesn't seem to make much difference to economy but does drive nice.
R
R8Chris
Thanks John, Will give Sainsbury a try. Thats my kind of science, Especially if it's gonna give me more smiles per gallon
