Whining Benz
BClassChris
PRESTON Lancashire
Mercedes B180 CDI (2009)
I’ve noticed today that my Benz is whining a little bit when the engine is under load between 16-2000rpm. It’s not the box I’ve checked the oil and had the box sat in neutral and done a rev test and the whining starts at around 16-2000. Just wondering does anyone have any pointers or could I be stalking a mind ghost.
My next port of call would be to look at turbo seals and turbo fins
TIA
Available at: https://zeppelinit.com
Hope you have a great day
Before doing that remove the auxiliary belt and see if the whine goes away.
B
BClassChris
PRESTON Lancashire
Doesn’t sound like a belt whine though from what I can hear it sounds more like the whine you get when your box is in reverse and your backing up a bit quick. I mean I’ll try it like see if it is that. Do you think the belt is on its way out?
Craiglxviii
Cambs UK
To be fair my cars experience a whining sound, but only when the Mrs is in the front passenger seat!!
ajlsl600
france
if it has serpentine belt. drop it off for a min and see if whine gone.as per craig. i have a knob on the dash and wheel that deals wid dat. its called volume control.....
B
BClassChris
PRESTON Lancashire
Forgive me for being a little dumb but let’s say taking the belt off cures it could I be looking at something as easy as a new belt or could we be talk £££ for alternator etc
It'll narrow it down to what's driven by the belt. It could be the belt tensioner.
ajlsl600
france
belt tensioner,alt bearing ,ac pulley bearing ,if ac fitted ,water pump bearing and whatever else is driven by that belt ,if the noise goes spin all the driven bearings,pulleys by hand ,if there is a bad one it should be easy enough to spot noisy or loose bearings
B
BClassChris
PRESTON Lancashire
Sit rep - I can’t get the ****** thing off as I’ve only got drive in ramps not lifting ramps going to get a garage friend to do it - will advise later
B
BClassChris
PRESTON Lancashire
Sit rep 2 - car has been to garage it was a tensioning pulley that was dead - all sorted now like new
CDK Motors Halifax Sorted within a few hours
