- Aug 25, 2006
- Location
- Midlands / Charente-Maritime
- '93 500SL-32, '01 W210 Estate E240 (RIP), 02 R230 SL500, 04 Smart Roadster Coupe, 11 R350CDi
If using over winter make absolutely sure the boot is bone dry with no leaks.Thanks LostKiwi I appreciate that! Two rear tyres and diff all isn’t all that expensive in the wider picture I suppose.
I do intend using it as a daily through the winter until my garage is sorted for next year so I want it fit as a fiddle.
The seals do have a habit of leaking and that can destroy the PSE pump (which is expensive). Check the pump regularly to ensure the foam case it sits in is dry and fix leaks promptly.
