whistling noise
Paulmar
Loughton essex
w204 2012 C220 CDI estate
got a whistling noise after I first drive off but only happens on first pull off once car started I have changed both the two bottom intercooler hoses as know they are common to go but have still got the noise any one got any idea as to how to check or where to look for the source of leak
oigle
2003 ML270 sold but not forgotten. 2022 Kia EV6 GT Line RWD
Could be an exhaust manifold leak that seals quickly with heat expansion once running.
rifiki
Worksop
CLK W209 W121190B
Have whistling noise on overrun 55MPH or higher, its been like that for last 9 years. Shows nothing on STAR
mattkh
England
A160 W168 1999 1.6
Do you hear the whistle if you increase the revs when idling..?
john campbell
North East...durham
2012 E250 sport deisel
What about checking the air cleaner box is closed properly as it might have a small gap.......
mattkh
England
A160 W168 1999 1.6
So that means it is aerodynamics causing the whistle.
Get some electricians tape and experiment by putting it outside on the body. It comes off easily without leaving any marks.
By the way, when did you first notice the whistle..? Was anything done just before that..?
Totally this. Very common to have broken exhaust studs on some engines. As the manifold warms up it seals from expansion of the metal and the noise goes away. It will only get worse unless fixed.
Paulmar
Paulmar
Loughton essex
noise goes within 30 seconds and don't come back until car fully cold and restarted and 30 seconds driving
mattkh
England
A160 W168 1999 1.6
Give that there are 5 to 8 of these studs, it must be difficult to pinpoint the stud causing the whistle.
Jason63
C63 AMG
Exhaust (and manifold) leaks are often visible due to the soot they leave behind.
rifiki
Worksop
CLK W209 W121190B
mattkh Its not aerodynamics. Lift off the whistling noise starts with no decrease in speed.
If it was aerodynamics the whistling would be constant at certain speeds, its not, only on lift off
oigle
"only on liftoff"??? You never said that before.
rifiki
Worksop
CLK W209 W121190B
On over run, foot off loud pedal/accelerator
Well you can now forget any posts saying manifold leak. Whole different ballgame.
The OP didn't say that it was overrun.
"On first pull off".
That says manifold.
oigle
That says manifold.
Yep. Got me there. 2 different posters with 2 different problems.... wish people would start a new post with a new problem instead of crashing in on a current one.
Paulmar
Paulmar
Loughton essex
  • #19
mines when first pulling off when car is cold and lasts for a few seconds
