Another one added to favourites thanks malcolm
Your starter solenoid may have a 12v feed out to your ignition to bypass a ballasted coil feed to give better starting ie 12v feed to ign coil when starter cranking 9-10v feed to coil when engine running via ballast resistor. If your car does'nt have that type of system then that starter may then fit other vehicle(s) that do
