Why does this rattle???
StuggyZX10
Hi can anyone say what this is and actually does??...this seems to rattle when my car a 1999 300td E CLASS ESTATE starts up when cold...if i put some pressure on it with my hand when it is rattling it goes away. and when it warms up it stops...at first i thought my timing chain was goosed, then my water pump, but it seems to be this part which is the culprit...is it some sort of damper??....thanks in advance Stu
Cole@MBS
www.mbssouthampton.co.uk
Thats the damper for the belt, the rubbers go soft, only cure is a new one!!
Alex Crow
Super Suffolk
as colin says above ^. it can be left as it is but the noise is annoying. although it may look easy to replace, the bottom bolt will need either the tensioner arm or the pulley removing to access.
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Common fault on the 606 engine. You can sometimes get round the problem (the break up of the top metalastik bush) by removing the top bolt, inserting a thick rubber washer between the block & the tensioner & nipping the bolt back up again
Nick Froome
www.w124.co.uk
StuggyZX10
Thanks you for the info ..was getting worried :( it was a bank loan of a repair will nip along to my local scrappy see if he has any ...thanks again
They are cheap from MB and not worth using a secondhand one
turbopete
Spennymoor
i priced one for my car. about £40 from MB
StuggyZX10
Got one today from Eurocar prts £29 will get it fitted at weekend, in the meantime did what was suggested by Bolide and stuck a large rubber washer behind top bolt........no more noise!!....:p
bought myself a peter russek pocket mechnic workshop manual last night so hopefully wont have to question you guys for info to much...
thanks again for the help and info
As long as you are happy,,thats all that matters:D:D
