Probably 130NmWhat would be the NM on a CL500 W216.
I had to get a damaged locking nut off my car about a year ago. I called a mobile tyre fitter who advertised his ability to remove locking wheel bolts. He set up an axle stand at the same height as the bolt then rested a long steel bar with a pointed end on it and smashed it into the joint between the rotating collar and the bolt. It broke in two immediately and when it came off he applied one of the "reverse claw" type of sockets with a two pound hammer. Once that was securely on, he put a three foot bar onto an extension and used the axle stand to support the extension horizontally as he wound it out. It all took five minutes and he went around and replaced all four lockers with standard bolts as well for £25. Apparently, the secret is to properly support the socket to prevent it twisting off the bolt. I've done this with a two foot bar when removing various wheel bolts and it works. It's much easier than just applying a wheelbrace and jumping up and down on it.
I'll went to order the locking bolt key, but MB want the code apparently it should be on the code options in the back of the service booklet (that's helpful, the misses was out in the car) when my new key arrives I'll be using your axle stand method
My local fitters (Ridgeway Tyres) always torque the wheels and ask you to drop back in after 50 miles or so to have them checked.( but I still check it myself)
but unless the gaffer slackened off the bolts/nuts & started again, if he just used the torque wrench again he'd no way of telling if the bolts/nuts were over tightened....... About 5 or ten minutes later (when all the Bills were paid), the 'gaffer' went round re-torquing them again.
My local tyre place uses air to spin the nuts on, and then the torque bar to finish tightening. I sort of hang around to make sure I hear the torque bar click on each wheel, it just makes me feel better lol
125Nm on my 216 with 20 inch wheelsWhat would be the NM on a CL500 W216.
A friend did a variation of this which took 5 minutes. Broke the rotating collar off with a sharp chisel. Pulled the outer bit off the splines. Welded a very large bolt to this bit and put back on and removed with a normal socket.I had to get a damaged locking nut off my car about a year ago. I called a mobile tyre fitter who advertised his ability to remove locking wheel bolts. He set up an axle stand at the same height as the bolt then rested a long steel bar with a pointed end on it and smashed it into the joint between the rotating collar and the bolt. It broke in two immediately and when it came off he applied one of the "reverse claw" type of sockets with a two pound hammer. Once that was securely on, he put a three foot bar onto an extension and used the axle stand to support the extension horizontally as he wound it out. It all took five minutes and he went around and replaced all four lockers with standard bolts as well for £25. Apparently, the secret is to properly support the socket to prevent it twisting off the bolt. I've done this with a two foot bar when removing various wheel bolts and it works. It's much easier than just applying a wheelbrace and jumping up and down on it.
but does the bolt/nut turn with the torque wrench before it clicks? If the gun winds the bolts/nuts to 1000 ft/lb & the wrench is set to 100 ft/lb then the click will mean SFA
Windy guns should never be used to start bolts off or pre-tighten them.
Starting off with a windy gun is a great way to cross thread the bolt and very quickly chew the first 4 to 5 threads of the bolt and hub.
How can a lock nut be tightened so hard that it breaks the nut adaptor when trying to undo it?
Could it have been tightened correctly and rusted in place?
I use a light smear of coppaslip on the threads but never on the face of the bolt that touches the alloy wheel.
Many will say this is wrong but I've never had a bolt come loose or rust and seize in place...............
My spec is 150 N/m, and althought my torque wrench is kept away from possible damage and wet in a drawer I add a little as I can't be sure of its calibration after the many years I've had it.
The local tyre place initially use their air gun and then a torque wrench to my specified torque, in the past they've asked my to sign a disclaimer as they've considered my torque to be too low. No problem I check again when I get home anyway.
Recently I bought one of these to make things easier and faster, and feasibly rip those awkward sods out.
Ryobi R18IW3-0 18V ONE+ 3 Speed Impact Wrench Bare Unit 689989391271 | eBay
On setting 2 I've still the need to torque up afterwards.
I've not had need of setting 3 yet but with it's impact driver style hammering I think it could well do better than I and save my shoulders.
