Will the door trim remove - W202
sol_khn
Bucks
Hi Guys,
I am new to this...so please be gentle with me.
My predicament is this, I have a 1998 C250 TD Sport, I like the old girl and have just spent a fortune having all the problem body work I've accumulated over the last six and a half years of ownership fixed. My drivers seat is shot to pieces and went to my breakers yard to buy another one. They will only sell me a complete interior and it doesn't match what ive got in there at the moment. My question is this, can i remove the wood trim from the new door cards and replace it with the carbonfibre trim on the origionals so it matches my centre console?
Many Thanks in advance
Sol
Hi Sol yes I have just changed all of the trim in my 230 SL its quite easy to do
The photo shows the trim that I am changing other members have done the same car as you
sol_khn
Bucks
Thanks mate, The trim i'm trying to remove is circled in the pic, will it just prise out? is it glued?
Sol
whitenemesis
CLS55 AMG '05
I think you have to remove the door card. Trim is held from the back
JBM5
Lancashire, UK
w211 E320i Avantgarde with all the toys
Hi Sol, you need to remove the door panels and the carbon trim is held on by small clips onto the back of the panel.
To remove the trim panels prize out the bung under the handgrip on the door panel and remove the screw. Prize off the bezel surrounding the interior door handle. If it is the airbag model prize off the SRS badge on the trim and remove the screw that is behind. Then carefully prize off the door panel using a broad flat tool. finally lift the door panel from the top of the door where it meets the glass.
I hope this is a bit helpful. If you are a bit handy I'm sure you will suss it out!!
Cheers John.;)
The trims have clips that are best removed with a pair of pliers using a twisting action
Dec
Ireland.
W202
The 4th picture HERE will give you further insight into how it is held on, the only difference is cosmetic.
Dec
bigasotonuk
Southampton UK
C43/55 AMG 1999 / C230K 1997
Be careful not to turn your ignition on with the airbag disconnected as this bring up a fault that has to be cleared by code reader or computer via the diagnostic socket.
sol_khn
Bucks
Thanks for all your help, just one more question please, my rear windows are manual, will i need to cut a hole in the rear door cards for the winder if they are off an electric window model?
Many Thanks
Sol
You may have too I dont think that they use blanks in the hole anymore
I have a punch you can borrow if you wish
kth286
E320 Coupe 95
sol
what's the problem with just getting your seat repaired ?????????
sol_khn
Bucks
Hi Guys,
Just to update, went to the breakers and found out an old friend of mine was working there. So I got a good deal on some good condition seats, the interior matches the door cards so i'm not going to bother to change them. just going to give it a good Valet. I also manged to get a replacement console lid new gear/gaiter piece and kick plates. So I think that will address all the inerior issues. Thanks for all your help guys, especially you... young Malcom..;)
Sol
www.ckinsurance.co.uk
