lmurthwaite
Hi all, new to the site and love my CLS. I have had an annoying window rattle ever since I got it and today thought I'd tackle it. Couldn't find anything loose anywhere in the door card or around the window mechanism. One thing I have noticed though is when the window is fully wound up the metallic rattle happens when going over small bumps etc. If I crack the window very slightly downward the rattle stops. It seems as if when it is closed there is metallic contact somewhere. Can't seem to get up inside the door when the window is fully closed and there are no access holes up there to poke around in. Next job would be to look down the outside of the door but I dare not tackle the chrome door trim as I'm sure I'd bend it or damage it. Anyone else had this joy with a CLS?
Also have bad interference from the radio when the rear demister is on. Discovered today that the rear window has been replaced so need to get in and check the connections from the aerial to the demister grid. Anyone know how the rear quarter trim panels come off so that I can avoid hacking them about?
