Window switch replacement help request 2016 e class coupe (207)
Ray Dancer
Chester
C class 350e premium plus reg Jan 2018
Hi members my passenger window goes up but won’t go down from driver side and returns to half open when operated from passenger side. Tried all the reset suggestions. The Merc workshop has quoted £274 to supply and fit new switch! I can buy the switch for £40. Can any kind soul advise if it’s possible to replace the driver side window switch assembly and to the passenger side without having to disassemble and remove the door panel and it’s fittings. Passenger side at least looks like it may pop out? I believe the wiring is simple plug and play.
Larkone
NW Essex
C219 CLS 320CDI 2008
Looks like there bolts involved - download the two files in post 3 - (16,17 on second doc)
