windscreen washer bottle w211
ben16rose
chatham kent
w211 e class
Hi this is my first posting pls excuse any errors. I need to access the windscreen washer bottle on my w211 e270cdi avantgarde as it appears to be leaking.Any advice wud be appreciated. :confused:
Hello and welcome.. would you like the instructions for removing the tank
2 papers sent
slimeddie
Television
I have today found I have the same problem. it has been dripping for 5 hours now from
the nearside front wing where I understand the washer bottle is housed. Could you please send the instructions to me as well.
Hello and welcome..why not pop your email address in your profile and click save at the bottom
slimeddie
Malcolm
I think my email address was there - it was just that I hadn't ticked the box to receive emails from other members - I think. Anyway, I hope I've got it right now.
OK see what I can do
2 papers sent,,one for the bottle and one for the wheel arch liner
eclassbob
New Registration
WARWICK UK
E CLASS 320CDI W211 2004
Hi Television, would you be able to send me details on removing the washer bottle on my W211 E320 CDI 2004 ESTATE, just started leaking, guess the big freeze has split it, Much appreciated
Ubique
W211 E320 CDI
Leaking water bottle
My screenwash water container, behind the body, work is leaking. I would be grateful if someone could provide me with details of how to reach the bottle for checking. Thank you.
Sorry I was away when you posted this
I need an Email address please
Most times with these is just the seal from the neck to the bottle leaking, no need to remove or even touch the bottle!!!
jberks
Guys, as above, the neck is a very common leak point but if it's emptying entirely then there is a rubber bung in the bottom of the tank that can perish. The old man had this on his 2003 E220. Again, easy fix and no need to remove the bottle.
Ubique
W211 E320 CDI
I am having the same problem with a leaking water bottle. Can anyone provide me with direction on how to access the bottle please.
capricorn1
ireland
e200 2003 1.8
Hi would you be able to send me those instructions on removing the washer bottle in the w211 aswell thanks
dave
