Windscreen Washer System
Headhurts
Norwich, Norfolk
Mercedes GLC300 2021
I recently had the windscreen washer bottle replaced on my car and as the weather has been pretty wet recently when it came to topping up I used de-ionised water to top up the system.
I have read somewhere on previous threads that some people use this or distilled water.
I was reading the hand book today and under the relevant section it says ‘Do not use distilled or de-ionised water in the reservoir . Otherwise, the level sensor may be damaged’
It seems strange to me that water that is more purified than tap water would damage a sensor, I would have thought the opposite would be the case.
This thread may be or not useful to those using purified water in cars with a level sensor.
Robin
EmilysDad
Bury Lancs
ML350
I just use 'Corporation Pop' .... It's good enough here to top your battery up. :D
Not sure how it would damage the level sensor though anyway, they're normally a float with a magnetic switch inside.
Sloss
C350 CDi BlueEFF AMG Sport Plus 5 Door Auto
Robin
It’s the ions in the water that allow current to flow across the sensor so that it can work.
De ionised won’t break it - just stop it sensing!
Headhurts
Headhurts
Norwich, Norfolk
Many thanks that makes sense I suppose, cars are getting more and more complicated I liked the idea of a float though.
Robin
L John
W204 C350 Petrol Elegance
I'm guessing the sensor would "think" it was empty at any level as it can't sense the water and so the warning would show at all times whether full, empty or anywhere in-between?
If so and the low warning is not showing when it's full, it's sensing the water being there and will warn ok when the water drops to the low level?
Headhurts
Headhurts
Norwich, Norfolk
Bloomin heck, now I’m more confused.
