windscreen wipers stopped
nix17
midlands
c180 coupe
help please
my windscreen wipers have stoped working - not good as its raining really badly
they only work when i press them in to do the screen clean - the water squirts they do their 3 wipes then stop,
thankyou
welcome to the forum,,what is the car please
If the car is a 203,,then the stalk will have failed,,some folk manage to clean them,,it is a steering wheel off job to replace it
N
nix17
midlands
c180 coupe
hi,
being a novice at this sort of thing what do you mean by 203? re; the stalk a few weeeks ago i had difficulty with the indicators staying on but they are fine again now, should i check the fuse? or as they work when pressed in is the fuse ok?
any advice gratefully recieved
N
nix17
midlands
c180 coupe
thanx Dec, it is a 203 then - i'm going to check the link now
hi,
Yes the 203 bit relates to the model of the car,,as you said "coupe" this puts the car in the 203 class of car.
Yes the indicators are all part of this,,there might be a re call on this switch, this is not a fuse problem
Check the bonnet is fully closed, has a wiper kill switch fitted into the bonnet latch!!
N
nix17
midlands
c180 coupe
Thanx for all the above help and advice, hopefully the rain will stop tmw and i can get to my garage - atleast now i will know what to say to them re the fault, dont think I can fix this one myself
Do you need an indie,,where are you in the UK
N
nix17
midlands
c180 coupe
the bonnets been up and down like a yoyo today as i attempted to find the fuses!!!! Which i now know i didn't need to do.
Pretty sure it is shut - im going to brave outside and have one more try, open shut everything turn everything on and off and plan a day around visiting the garage twm
thanx again everyone
N
nix17
midlands
c180 coupe
ive got a really good indie garage bout 5 miles away, im in the midlands
Other thing they do, the wiper arm cuts the wiring, seen a few of those, scuttle panel off to see it tho!
N
nix17
midlands
c180 coupe
back from checks - bonnet def shut! - the indicators work but now the squity button for the wipers does nothing it's getting worse!
N
nix17
midlands
c180 coupe
its giving me no wipes now!
Thats OK it will stop raining in September,,thats the way the stalks go,,it is steering wheel off but not too hard or expensive,,the part cost around £87
N
nix17
midlands
c180 coupe
  • #20
thanx again for all the help and advice, will have to get it sorted out tmw, what a day for the stalk to go! Will let you all know what happens!
