i just filled my windshield bottle up to the top (1 gallon) It was pooring out the bottom and then at half full it stoped What is that all about ?if there was a hole in the bottom all of it would come out help and thanks
My car is a 1990 SL 300 The bottle has a heater in it Your must have one also So did you take that out also Thanks EdAgree with roofless, you don’t say what car you have but if it is a W202 like mine then take the windshield bottle out of the car and hold it up to the sunlight or put a light inside the bottle and you will see some very thin sections of the walls of the bottle, this is as a result of a manufacturing fault when the bottle was blow molded incorrectly.
The solution I used was to paint the inside with white car paint around the thin sections, where it leaked, make sure the bottle is completely dry first, The bottle is made from some kind of polly? plastic, the type that will not agree with mastic or super glue and is difficult to get anything to stick to it.
Dec
