The wing Mirror handle (drivers side) on my 1991 300TE is missing. What is the best option, if I shove a screwdriver in the hole will it work or will I break something?
if the missing handle has left a hole. They are easy enough to take off, just prise the triangular trim piece off gently and you'll see the retaining screws, if memory serves.
and it might be the trim piece on the outside you need to look at to get the mirror off, if you want it off. It was on my w202. These senior moments will be the end of me.
Only takes a coupla seconds to adjust it from the outside with the mirror itself.... My interior lever thing has almost siezed up, so I generally tend to adjust it this way anyway.
AMF Automotive - We are an independent Mercedes-Benz and AMG specialist located in Paddock Wood, Kent, with full Mercedes Diagnostic equipment. We offer a full
portfolio of tuning options for AMGs and can cater for all your Mercedes needs. Tel: 0203 384 4644www.amfmercedes.com/
