I did not use my 230E for over 6 months and as I tried it last weekend the wirpers moved half a turn and stopped. How to get to the motor to check it out and spray it with WD40? please help. Thanks.
If you haven't done so check the fuse. Even if it looks ok the ends of the metal strip can seperate from the strip or corrode. If it stops halfway then it is the costant feed that is at fault.
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
