Hi ; My ML270 ( 2005) has windscreen washer problems. They will not move under their own power , but do when I give them a hand ! the fuse is OK. Do I need to replace the motor or is there a mechanical issue? Can I get a second hand motor fitted?
Hi.
They are known for getting wet inside, hence have dodgy connections,and start to seize up.
Remove wiper arms, you may need a removed tool for this, remove rubber trim along front of scuttle, two plastic nuts either end and then fiddle the scuttle grill out, it takes a bit of fiddling. Then remove lower cover which will reveal wiper linkage. Four ten mm bolts hold it all in, linkage comes out with motor in plug the wiring.
Either refurb what you have or buy another proved working unit.
AIB understand your special Mercedes deserves a special insurance policy. We have a refreshing attitude to insuring high performance, modified, imported or classic and vintage cars and deal with the UK’s leading insurers. We offer discounts for length of ownership, where the vehicle is kept overnight and limiting the mileage and can also cater for those clients who need higher mileage and business use.
To obtain a quotation please call the team on 02380 268351 or visit us atAIB Insurance
