If I was fitting tow bar electrics to a 203, I would personally buy a dedicated wiring kit for that chassis, as the 203 has various issues with the SAM unit, and will require a relay or interface unit to maintain the correct operation of the bulb failure system.
In a chassis specific kit you should get all the items you require including relays/interfaces etc. and instructions on how to fit it correctly for your car.
Would there be a chance of having a copy of this wiring diagram as well? I am putting a towbar onto my 05 c220cdi this weekend. I have read about a socket which can sometimes be found with all the wires for a trailer to plug into. Where would this be found if there?
Hi Television - could you also send a copy of this diagram to me. Also will I have to remove the bumber to fit the towbar. It is a c220 diesel 2001 (51 - new shape).
If so any instructions on this too would be welcome.
Hi Televion, I managed to remove the bumber, fit the tow bar, and partially wire the trailer electrics to the relay switch. No for the fun part - wiring the relay switch to the vehicle loom. the cable colours are all different so I dont know what matches to what.
I have an estate - c220 cdi - 2001 (51 - new shae)
GAD was founded in 2009 where we developed bespoke ECU Remapping software for motorsport clients, moving forward, we have extended to road vehicles for both performance and economy, contact GAD Tuninghttp://www.GADTuning.co.ukto discuss your requirements.
