WIRING DIAGRAMS 1987 to 1997
Thanks a million dec,,I have asked for it to be moved
ig_Al_300te
Salford, Manchester. UK
'90 209k W124 300TE on LPG
Hello All.
Does anyone have an ecu pin out for a 1990 w124 090 300te with the ke jetronic fuel injection system fitted?
as im trying to diagnose a non running fault and want to check crank angle sensors and any component used to stop the car from firing.
Thanks Alex.
RFdesigner
Hampshire, UK
sites.google.com
W210 2001 320CDi 40k miles to date
Could this be put in the DIY section?
http://www.autolib.diakom.ru/CAR/Mercedes-Benz/
Click on the dropdown menu
Select year
Select model
Select WIRING DIAGRAMS
Dec
Anyone got the schematics for the W210 E320CDi (2001)... I'm lookinf for the 'A/T' one.. the autobox interface.
Judging from the 1997 E320 petrol I can do what I want to do... so I'll take a look with my scope and multimeter, but I'd really like to have the correct schematics, especially as my car is post face lift and schematics can change.
Derek
I have some but they are too hard to copy off and print :(
RFdesigner
Hampshire, UK
sites.google.com
I know I'm being a bit cheeky asking if you could check this detail, but here goes.
On the 1997 E320 AT schematic, Pin17 of the Transmission Control Module named PWM VLV uses a GRY/BLK wire to connect to Pin11 of the Valve Unit (the Lock up Valve).
Is this the same on the E320 CDi 2001 schematic?
my guess is as the transmission didn't change then it could be the same.
thanks in advance... plus a lot of grovelling!
Derek
stoneage
east midlands leicester
alfa, and merc 500sl 91 m119
wiring dig.
HI,JUST READ YOUR POST,RE WIRING DIAGRAM, I AM LOOKING FOR A WIRING DIAGRAM FOR a 91 sl and a96 s class mercedes, this is to see if the speedo can be interchange ,on my sl the speedo has stop working:confused:
Sadly the SL is not covered in those diagrams, loads of 129s being broken on Ebay.
Has someone fitted the wrong radio
stoneage
sl dig.
yes,after market radio fitted,{does this cause problem with cluster? I ve got a 96 s class cluster ,all gauges in the same place,connector lookthe same but ;when fitted blows the fuse#8:confused:
Yes the wrong radio can kill the speed signal, I would unplug to see if this is the problem and we take it from there
stoneage
speedo cluster
Thanks ,for your reply, this week end
ill unplug radio and let you know if it cure the problem
stoneage
speedo
HI,unplug radio, still not working, waitting for use cluster,will let you know if this cure the problem
It was worth a go as not many know that this can happen, not much shown for the SL on these circuits but you could use the 140 S class for the same year as they are near enough the same if you wanted to check voltages
kook
spain
w124 300turbo diesel
my word that television knows his stuff most of my elactric woes have been sorted today--a mouse had chewed through 4 wires below the fusebox destroying horn and screenwashers. however the red relay I replaced and tested using telivisions instructions worked for a few days then rev counter abs light tickover aircon all failed so bought another and the abs went out but the other annoying faults remained at least it passed the itv. replacing the bitten wires ,Inoted that near the overload relay, ecu and three other expensive looking relays there was tw wires also chewed off and I could not find corresponding ends so am hopeful that this is the cause of my woes, one is white the other is blue and brown. I have had the car for 14 months 2 tyres front half of exhaust and brakes changed out from a breaker I am over the moon with the car a1990 300turbodiesel my first merc was a 1953 220 the second aw123 diesel tank this is by far the best car I have ever had does exactly what it says it will with grace and safety and economy I live in Spain and the merc dealers charges are prohibitive and not familiar with any thing the age of mine.
So pleased that you have found the forum useful :D:D
vitasik
Knezha, Bulgaria
Merc w126 300se
Derek
Have you managed to get them? If not might be able to help you ( takes time to get them in the way that can be send by mail)
