Wondering if someone can help me determine if my C63 is in the affected Head Bolt M156 Engine range
N
NathanC63C63C63
C63 2011
Hi there. Nah I was told that there was a portion of 2011 amg's that were affected. There was an engine serial number thrown around on the other forum... if your engine number of lower then that serial it was affected, some 2011s were included unfortunately
flowrider
SL500 (R230)
Was there a recall on the head bolt issue? If there was then you could ask MB.
Engine number 060658 and on were modified yours is fine it’s 068838
Here’s your data sheet
  • wdd2040772a608246.pdf
MB never acknowledged or recalled these engines for this issue.
Submariner1
Windsor Berkshire
CL500 2009 5.5
I was told by my main dealer head mechanic ( who is brilliant ) the safe engine nos for CL 63s must be engine no ending greater than 60658.
He did advise me to avoid any prior to that, even if they had been recalled. He said they only fixed the broken ones!
I.e. possible slight damage before discovered.
Sadly there are many even quite late ones effected.
Very sad as imo the ultimate deep, deep, deep AMG roar ...
never surpassed ... biggest Pots!
^ There is an indy, on here, that has reported the issue with later engines than 060658.
Also, camshaft/lifter wear seems prevalent on all engines, see Tasos Moscatos on YouTube
HenryTt
E63
Hey guys,
i’m bit late to the party , i’ve been doing my research but not to sure if my e63 is affected can someone help me out please ‍♂️ 8234B854-0439-4154-AEE5-662EE816B463.jpeg
AMGeed
Poole, Dorset
S204 C180K
Hey guys,
Your engine number is 156985 60 067814 and is in the batch of engines where the headbolts have been updated.
Relax.
Welcome to the forum.
If you are interested, here is the full datacard for your E63 so you can see what was fitted at build.
HenryTt
E63
Relax.
Thanks for the reply! My Partner has just purchased an e63 2010 she hasn’t had any issues as of yet, to avoid issues can we just replace the head bolts to the updated ones? Or would their be more work required?
Sorry for the silly questions
AMGeed
Poole, Dorset
S204 C180K
Get in touch with Acid at MSL Performance in Birmingham. He has replaced these bolts on a few M156 engines and can talk you through the procedure and rough cost. I think he has managed to remove one bolt at a time and replace them with updated ones without the need for a new head gaskets thus saving a lot on labour and parts.
He may well advise that as the car is now 11 years old any corrosion and failure would have happened by now and to leave well alone.
Ruvem98
New Registration
2007 E63 amg
Can anybody check my 07 E63 for head bolt issues? VIN #WDBUF77X07B084233
Uncle Benz
West Sussex
Mainly Mercedes
That’s not a chassis number that I recognise at all
AMGeed
Poole, Dorset
S204 C180K
Although, IMO if they haven't gone by now, and the mileage is not very very low, then they are unlikely to be an issue.
