Would it be ok to cut and join car aerial cable
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by mercmancdi, Nov 20, 2012.
  1. mercmancdi
    mercmancdi Senior Member
    3,254
    699
    Dec 6, 2011
    templepatrick - co antrim
    Your Mercedes:
    2009 E250 cdi 08 cls320 cdi ,2007 e280 cdi '2005 E 280 CDI ,VW TOUAREG ,JAGUAR S AND xTO NAME A FEW
    I need a aerial fitted but don't fancy feeding the new cable right round and down to rear of radio so was thinking of cutting the new cable and joining it to the original one up at the roof ,,, or if I joined the new cable to the end of the old one would it ever pull through ,,knowing my luck it would probably get stuck half way. Any ideas ?
  2. Benzworx
    Benzworx Senior Member
    1,518
    10
    Jun 23, 2012
    South East
    Your Mercedes:
    CLK 55 amg
    RE Aerial
    Why would you want to fit an external Aerial ?
    clk's already have one :D
  3. bigasotonuk
    bigasotonuk Senior Member
    5,243
    9
    Nov 14, 2006
    Southampton UK
    Your Mercedes:
    C43/55 AMG 1999 / C230K 1997
    Are you trying to replace the original Co-ax? from the ariel amp at the rear screen to the head unit?
  4. television
    television Always remembered RIP
    164,074
    310
    Your Mercedes:
    You can do an in line join, antenna inner wires tend to be very thin a the coax is air spaced
    What you need to do is cut the outer plastic sheath off about 1½" back, push the braiding back and by using a pointed object you can separate the wires to make a hole in the braiding, bend the inner wire back on itself and pull it through the hole that you have made in the braiding, pull the braiding straight and you effectively 2 wires. now do not try and cut the plastic off the inner wire,use a lighter or match and get it hot and you can pull it off with your finger nail, you need about ¼" of plastic left. twist the inner wires together and solder, insulate, then twist the outer braids together and solder then insulate, or you could slide some heat shrink over the cable before you start.
    I did have some pictures on doing this, but they are gone,,,I can put some up tomorrow
  5. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
    Just to clarify its for a old w124 the aerials broke off .
  6. turbopete
    turbopete Senior Member
    14,204
    325
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    2010 '60' Ford Mondeo 2.0TDCi Zetec (sorry)
    cant you just replace the mast, like the 202?
  7. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
    Thanks you may be right as the cable may be connected with the eye fitting over the bolt in the mask. Have to drop interior light off to check.
  8. mikestrivens
    mikestrivens Senior Member
    2,715
    146
    Nov 21, 2008
    Stockport
    Your Mercedes:
  9. turbopete
    14,204
    325
    Feb 4, 2009
    Spennymoor
    Your Mercedes:
    theyre usually in the rear wing! is it an estate?
  10. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
    Don't know but this is 1995 ,its on roof front centre ,unless its been tampered with at a time.
  11. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
  12. paul hayward
    paul hayward Senior Member
    1,526
    Feb 27, 2012
    Your Mercedes:
    all MB sold..V70R now ;-)
    :lol:...the 1st thing i saw was....Would it be ok to cut and join car :Oops:
  13. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
    There's a few knocking about ,I bought a mini once and I left it into a local garage to check it on the ramp for rust round sub frame etc ,he rang and asked which one i wanted checked as he thought there was 3 cars welded together.:Oops: £250 down the drain.
  14. OP
    mercmancdi
    3,254
    699
    Dec 6, 2011
    Your Mercedes:
    Fitted aerial today and was able to use existing cable ,its much better picking up most M W stations but struggling with some F M , could the radio be a bit of a dud just stuck in to fill the hole.
    Any chance the old cable is getting a bad contact ie earth or if this was the case would it not pick up the M W stations so easy as it does.
    It's not the original radio.
Share This Page
