would really appreciate opinions or experiences
drmw
Yorkshire
www.autonomed.co.uk
Morning peeps - currently in Scotland in Saab 9-3 with no access to tools.
Car was MOTd two weeks back - I did ask that all bushes were lubricated to reduce the groans every time I went over a bump - they did & it has helped a lot.
However we now have a new loud annoying rattle - I can live with it for now but I would appreciate a second (and third) opinion re safe to drive.
Rattle difficult to pinpoint. Not a heavy noise, so thought maybe a heatshield - that I checked & all ok. Thought it might be a backplate (it's that sort of pitch) but no access but this isn't the noise you get with a stone stuck behind.
Not speed or rev related & seems to appear more with minor road bumps (the sort you hardly feel), ie speed bumps don't cause it to happen.
Tried this & that then pulled handbrake on a couple of notches - noise seems to disappear.
Is this likely to be cable or actual wheel mechanism? Anyone had similar? Most importantly, safe to continue driving until back home? The car is 2005 and I would guess this part is 100% Vectra
Thanks in advance
whitenemesis
CLS55 AMG '05
Sounds similar to the parking brake cable on the 203, where the clips break allowing it to contact the propshaft? Does the parking brake hold the car and release cleanly?
Any chance of finding a friendly garage where you could pop it on the ramps?
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
That was my thought process (although it's front wheel drive!) - however the noise could be the cable hitting the exhaust - it's that sort of tone. The mechanism works & releases fine though.
I'm on the Isle of Arran - not exactly over-subscribed with garages !
Oarsman
Norfolk
W221 S350L CDI Bluetec, Range Rover Vogue SE 4.4 TDI, 1963 Triumph TR4
Could be an ARB bush.
whitenemesis
CLS55 AMG '05
Front wheel drive!!! :shock: :shock:
Perhaps you could jack a wheel up, spin it and listen?
Are you with the AA/RAC?
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Well, someone has to use front wheel drive :Oops::Oops:
I don't think cover extends to the islands - at least not on the basis there's a unit over here!
It's impossible to describe a noise at the best of times, particularly in writing - it's quite a "light" sound, hence going for heatshield first. I would think an ARB bush gone would have been a heavier sound.
But, with just two clicks on handbrake (it probably goes to 6 if pulled on fully) all it's doing is taking up slack in the cable plus a little bit which could then hold it away from whatever it's hitting.
I'm almost convincing myself now :):)
Then this only leavers the handbrake cable touching something that it should not, so its under the car you go before it rains
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Rain? Here's a live webcam http://arranproperty.co.uk/arran-webcam/
That cloud is all that can be seen & is burning off the hills rapidly. The cottage is up on a hill immediately behind the line of sight of this (badly adjusted!) camera looking across the bay. It's sunny & warm (just right for the midges !!!!!)
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
taken 3 minutes ago from the garden
whitenemesis
CLS55 AMG '05
Ah! Midges, I remember them ... Flying teeth :(
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
This year however, the midges have brigades of minders - up here they are called "clegs" - see http://en.wikipedia.org/wiki/Horse-fly. They hurt when they get you.
Five bites so far including one 20 minutes ago scrabbling about under the car, so as far as I'm concerned, as nothing is going to fall off or seize or break, sod it, it can wait until I get home!!
Interesting the midge thing, when I was in Sweden, Jönköping as about as far south as I could go in the autumn, or they just ate me up, and always on the west coast and never on the east. Arron is pretty much on the same lines as this part of Sweden
whitenemesis
CLS55 AMG '05
Yes they do hurt! Midges are annoying but those horse flies smart..
Agree regards the car, forget it and enjoy your holiday :)
st4
Banned
Sunny Scotland
1-stephen-taylor.artistwebsites.com
Disqualified driver
Midges are not pleasant, but when i went to Italy last year the mosquitos were much more annoying. Wales was worse for midges than I've ever had up here in Scotland.
I had planned on a tour today, I need to get shots up at Lochan Na-H Achaillaise, Loch Tulla, Loch Etive and Loch Leven as its nice and green up here and it would compliment other images I have of this area but the weather is a bit too cloudy and it didn't clear until the best of the morning light has gone.
Later next week maybe.
Aside, if the OPs cover cannot cover the Islands (thats a new one) a local firm could tow the car to the Ferry and recover it to Greenock, of which a garage can fix.
Arran, never been, always fancied it, must do it.
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
Steve - the car drives fine, just rattles, so RAC/AA wouldn't attend even on the mainland. It could have been doing it for some time (I don't drive it that often) & you only notice at low speeds particularly with the roof down. The failsafe cure is to turn up the music!
ps - you sail here from Ardossan - if you went to Greenock you would have a bit of a wait ;)
And yes, you must do Arran - I've probably spent three if not four years of my life here - stunning scenery
aquanaut
Aberdeen
2020 C63s AMG
Nip on the ferry over to tarbert and go to the Skipness Seafood Cabin for lunch, you won't be disappointed!
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
  • #18
the plot thickens - as before a couple of notches on the handbrake kills the noise - as does gently pressing the footbrake.
Do any cars use the same pads for both foot & parking brake? If so, maybe a caliper slightly sticky letting a pad rattle against the disc when the brakes are released?
drmw
drmw
Yorkshire
www.autonomed.co.uk
  • Moderator
  • #20
www.ckinsurance.co.uk
