pivers
can someone please take a look at this photo and tell me if this ball joint looks right. The taper is definitely right home but I'm not sure about the gap between balljoint and hub casting [about 4mm]. The joints were supplied by europarts and I have to admit that even if they are seated right they're still crap. The rubber boot on the other one has lifted away so that I can see under it which obviously means It'll need replacing in the near future due to dirt ingress. It was only held in place by a feeble piece of coil springing and must have came adrift during fitting even though that side dropped straight into place without any problems. I intend to replace both joints with genuine merc parts but would like to know if I'm safe for the time being. Reason I say this is that the first time I used the car after fitting the joints I lost control on a bend near here. I have to add that it is a notorious accident black spot and the road was wet and outside of a farmyard but I have travelled that way hundreds of times without incident. I can definitely say that in the 4 years I've had this car [97'c250 td sport] I have never had anything even resembling a skid and I was very surprised how hard it was to control the car in this one, having to correct the fishtailing 4 times, luckily on a deserted road.
As always I'd be grateful for any input,[Except snide comments about my driving]
Cheers
Pete
p.s. Still trying to insert photo.
Cheers
Pete
