Unless the mechanism is cream crackered...Xenon headlights do an up- down- lefty- righty dance when turned on, too.
They still identify as Xenon though. Xhe/ xhim.Unless the mechanism is cream crackered...
This is the best way, or alternatively pull the lamp out of the back and have a look…Easy way to tell is by looking at the back/top of the headlight cluster, if they are xenon they will have a warning about electrocution on then. Other quick way would be to post a picture up of what you have, we should be able to tell you pretty quickly
Hey, don’t let something easy like that ruin a good threadThis is the best way, or alternatively pull the lamp out of the back and have a look…
Certainly looks like xenon from that pictureThis is my headlight, by the looks it's a xenon one
Ballasts are replaceable and don’t need coding.Can you replace just the ballast module, or does it need to be the whole unit?
Both of mine do that and they're LED's.Xenon headlights do an up- down- lefty- righty dance when turned on, too.
Not necessarily- my C207 (same platform as OP’s) had Halogens with projector lenses. (Yes, they were halogen and bl00dy useless)Certainly looks like xenon from that picture
I've tried new bulbs, and light still not working, it's what to do nextNot necessarily- my C207 (same platform as OP’s) had Halogens with projector lenses. (Yes, they were halogen and bl00dy useless)
That’s your problem… you’ve non halogen lamps fitted to halogen units. The light source won’t be in the correct position for the reflector so giving a poor pattern - as well as blinding other road users and being illegal to boot…View attachment 78044 These are the bulbs that are fitted
