EmilysDad
Rubbish breaker bar if you're able to do that (or you spend a huge amount of time in the gym).
We managed to breaker a 3/4" drive breaker bar at work .... there were 3 of us hanging off it though
You've to watch what they're doing where ever you take your car.
I'm in the middle of replacing the grotty OE centre caps on my ML. Rather than just prise the originals out I thought I'd remove each wheel in turn & just check that they would in fact come off and grease stuff up. No amount of hitting (with the heel of my hand) would shift the first wheel ..... 2nd wheel I'd to swing off my breaker bar to undo most of the bolts and ended up with yet more blasted stainless caps coming off the bolt, I wish that garages wouldn't use rattle guns to remove/refit wheels, some of my bolts are now beyond refitting.
The last wheels to come off my car were the rears to check balance at a local independent tyre place and it was a rear that I'd to swing off the bolts.
Putting any oil or similar on wheel bolts means the bolt will be tightened way past its intended torque when checking with a torque wrench ! .....
copper grease which apparently went out with the dinosaurs.
