zenon auto leveling problem
NYorkshireLad
Darlington
C220 sports coupe pan/evo
Hi i have a c220 sports coupe 2004 with zenon lights :D, when i first got the car i found that the auto leveling was directing the lights low down only giving me 2 meters of vision but after a day or so it sorted itself out and had no problems ... til now and its doing the same again , can anyoune help with this problem:Oops: ?
whitenemesis
CLS55 AMG '05
Sounds like one of the axle sensors has gone out of spec.
Have you had any service work on the suspension?
There are sensors on the front and rear ARBs that control the auto-leveling
P.S. Welcome to the forum! :)
Welcome to the forum,,and as the above post one of the front or rear axle sensor will be faulty,,quite an easy job
whitenemesis
CLS55 AMG '05
It might just be out of adjustment, they are very sensitive to positioning. Took a good 30min to get my front sensor adjusted correctly..
Yes I agree could even be an arm dropped off,,and this has been up before
N
NYorkshireLad
Darlington
thanks , i have had no work done to the suspension , so i will get onto investigating the problem when i get the haynes manuel .... im glad it sounds like a cheap fix anway :)
The rear axle one is here
And the front axle onehere
N
NYorkshireLad
Darlington
so the part i need to adjust or check is complete is 100 on front and 10 on rear . how do i adjust them ? thanks
whitenemesis
CLS55 AMG '05
Can only be done using STAR. One needs to set the zero point with the car set level.
This will not be an adjustment fault,,the operating arms can come off or one has failed electrically,,at a push the fault my be in the lamp control box,,but doubtful
Wirral_guy
Ness, nr Chester
2004 CLK270cdi Avantgarde
This is quite common on the Alfas. The sensor arm bracket rusts and snaps leaving you with lights too high or low. To confuse things it is also intermittent at first as the 2 sides of the bracket catch on each other so the position changes randomly as it is free moving with no 'home' position!
If that is the case I fixed the Alfa's bracket using a similar shaped L bracket and adjusted on a flat surface until the lights looked right on a close wall before tightening off - I got the reference point from another car pointed at the same wall. Saved buying a new sensor and/or getting it re-calibrated (although the Alfa sensor seemed to be little more than a linear pot so may not have required any calibration)
Dave
www.ckinsurance.co.uk
