08Clc Drivers Wing Mirror Removal
CooperM
Dagenham, Essex
CLC 180 Kompressor
Apologies if an answer for this request has been posted already but unknown to my eyes i cant see it..
Does anyone know or can guide me how to remove the glass from a 08Clc drivers side wing mirror, Ive seen various posts regarding wing mirror glass in which most point to a wire behind the glass for removal but it seems my model doesn't have this mystery wire...:eek:
The mirror was hit, breaking the indicator. Ive purchased a replacement casing with inbuilt indicator (£100)...Mercedes require at least another £100 just to fit so any help will be greatly appreciated...:)
I can help you within a few days with the instructions
C
CooperM
Dagenham, Essex
CLC 180 Kompressor
Yes any help would be much appreciated....
Fiddling about with the glass today i discovered that it just literally pulls off with a bit of pressure, This then threw up another problem after removing all screws on show the mirror was still none the looser, I'm now wondering if the whole unit needs to be removed for the casing to be changed.
whitenemesis
CLS55 AMG '05
Is the clc anything like the 203?
[YOUTUBE]wNHbdjrtkiQ[/YOUTUBE]
I had a PC that went down with all my info, can you pop up your Email address for a few mins and I can send you a few different ones that could be the same, you can edit it out in a few mins
You have to remove the three motor drives to do it, there are three screws holding the motor drive on, 1 at 9 o'clock, 2 at 1 o'clock and 3 at 5 o'clock
whitenemesis
CLS55 AMG '05
I think the OP only wants to replace the mirror casing/indicator??
sexypin69
CLC 2008 1.8
Also I need help same problem 2009 CLC
neil12000
Registered
slk 230 r170 2004
I need to remove my clc 2010 mirror cover to replace the led .can someone send me a link or instructions on how to do this thanks .mirrors seem slightly different to a w203 or w204
E mail
neil.slater@tiscali.co.uk
Dean Fletcher
Penrith, Cumbria
Mercedes E400
E mail
Do you have a photo of the mirror? Might be best starting a new thread @Blobcat might be able to help with that.
