18v impact wrench
flowrider
SL500 (R230)
I'm looking to buy an 18v impact wrench, what do people recommend is a decent but not overly expensive make.
Oldspanners
Normandy
C CLASS 2004 C180
In the same boat myself, I've a notion just to go for a Parkside (Lidl) the next time they come up but have seen various reviews differing in their effectiveness at high torque. Seems to be the best thought of are Milwaukee, Makita or DeWalt but they are in a different price range so for my occasional use probably a luxury.
daveenty
The Frozen North :(
2019 AMG S Class Coupe
As inferred to above, Milwaukee really are the go to people in this field.
I bought something inferior a long time ago and ended up just using it as a nut runner as it wouldn't move anything with any torque applied to it. I even had to crack wheel nuts with a breaker bar before I could undo them. :(
ajlsl600
france
I have been using roybi for a few yrs .does everything I need.only reservation batteries not cheap. I am about to try 2 ebay jobs. Dont bother with less than 4ahr jobs
flowrider
flowrider
SL500 (R230)
Looking on Amazon the Ryobi is at the top end price wise which for my usage is overkill. I want the wrench to work but ideally spend around £100ish. I have seen cheap wrenches rated at 420nm and expensive ones rated at 190nm, I assume this is torque ratings that the wrench can undo.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Wheel bolts are around 90 - 130nm so that will give you an idea of how much power you need
ajlsl600
france
144 euro on amazon .dont seem too bad I had mine working hard for 8 yr.
I have the Ryobi and find it a nice bit of kit. Has 3 settings so can be used at lower torques too.
star
Reading
Smart + others :)
We have Mac and dewalt. Shifts far more than an air impact gun.
bob 6600
Audi S8 V10, S210 E320 CDI (R.I.P.)
I have the DeWalt and it's brilliant. Even though wheel bolts are usually not more than 130Nm (as stated), they are often 'monkeyed' on by wheel guns. The Milwaukee is even better but the price is much higher than the DeWalt.
I went for the DeWalt for a few reasons.
1. The power stated was around 900Nm breaking torque so should do everything
2. I was in the process of updating my old DeWalt drill and so bought a drill, batteries and charger before so just needed bare tool
3. The price as a bare tool was not as much as you think
4. The 4ah and 5ah batteries can be bought from reputable sellers on ebay for about half RRP
5. Gave me an excuse to buy more tools to fit the batteries :D
Jason63
C63 AMG
Yes wheel nuts should be done up to 130Nm but often it's more, however whilst mine are always torqued up correctly when it comes to undoing them they always needs a lot more torque, I'd say double at least if the wheels haven't been off for a while.
Oldspanners
Normandy
C CLASS 2004 C180
Just was having a look at this last evening :rolleyes:
https://www.ebay.co.uk/itm/324211287592
ianplymouth
Plymouth, Devon
SL55 amg, Renault G Espase 2.0Dci 175+, Megane 265 cup
I bought the Lidl one in there last promo seems quite good so far and for £60 it included a battery, charger and some impact sockets.
I have a Ryobi one as well, that I've had for years, used it an awful lot, but mainly for taking the wheels off and on for my track car and every one else's, also for stripping cars and engines.
Frontstep
T210 320cdi
A man who does a lot of work for me uses "Lidl Power" as he calls it and I have to say it does the job, the warranty is fantastic and he just gets another one sent if it fails during the three years.
Bay Leaf
Stockport
SL 350 R231 2013
I have a impact driver which is great for tough jobs around the house woodwork etc. I do use it on the car for wheel nuts etc but they have to be broken with a bar first. What is needed for heavy duty work is an impact wrench which normally has a 1/2 inch drive. The more you pay the more power you get.
Chrishazle
Nr Ashford, Kent
Avoid the Lidl/Parkside 10.8V version, they claim it will put out up to 400Nm on breakout but only 100Nm on make-up, which to me appeared perfect as it should release nuts origianally torqued to 130Nm but be unable to overtorque tham putting wheels back on. It's a released nut wheel spinner only, has never been able to release a correctly torqued wheel bolt. Damned annoying, as my COPD meant I had a major problem even jacking the car up when I got a flat, was rescued by some passing walkers who saw how I was struggling for breath and rescued me, took over and changed the wheel for me.
bembo449
gainsborough , lincolnshire
When my snap on gun finally dies i will be getting a dewalt to replace it , my local tyre place use them and they get alot of stick , so a good test which they seem to pass easily
www.W140.co.uk&www.r129.co
