2001 CL500 Dash clocks and lights stopped working, fuse?
Mikesmerc
Co.Cork IRL
2001 CL500,1990 560SEC, 1988 230E, 1982 250, 1979 280CE, 1977 200D, 1972 350 SL, 1965 220S Fintail
Hello all, as above and the headlights on even though the switch is off, I have done a search for the fuses and it tells me that F79, f84 &f 85 are the cluster fuses located in the cockpit, anyone know where this box is located, Im aware of the two under bonnet ones and the back seat but i cant locate the fourth.
If the fuses turn out to be OK, can the cluster be repaired at home?
Thanks guys
Rgds
Mike
Naraic
2005 CL500.
Sometimes there is a fourth at one end of the dash...but usually not.
Mikesmerc
Co.Cork IRL
Yes you are right , I think 2002 and later had, so anyone know the location of the dash fuses for a 2001 model?
Craiglxviii
Cambs UK
Yup, under the hood.
Mikesmerc
Co.Cork IRL
Thanks Craig, left or right box? Number?
Ta
Mikesmerc
Co.Cork IRL
If I discover that the cluster is faulty, can a secondhand one be swapped without star diagnostics ?
Craiglxviii
Cambs UK
Sorry, don't think so. The cluster combimeter contains odometer data.
Mikesmerc
Co.Cork IRL
Ahh yes I see, lets hope its just a blown fuse then.
Mikesmerc
Co.Cork IRL
Thanks Steve, found the culprit since. a blown 5A fuse, alls well again
Thanks all
Rgds
Mike
Alex Green
Cl500/2000/V8 5.0L
Just out of interest, was the fuse in the location described by Craiglxviii?
The charts say F78 to F86 should be in the end of dash but if you don't have that then how are they distributed?
I also have an early CL and would like to know where the fuses are scattered when you don't have the end of dash fuse boxes.
Ta
Alex
Mikesmerc
Co.Cork IRL
Hi Alex, they were in the passenger side box under the bonnet, midway there are three 5A fuses together, I dont have an under dash fuse box and I think 78&85 refer to this location in later cars. I think the fuses are 19,20&21, couldnt really see as I hadn't my specs on, just going from what I googled.
Rgds
Mike
Mikesmerc
Co.Cork IRL
This is the chart I found
  • W215 fuse & relays left engine bay.pdf
Flyinspanner
Ruislip
The 2001 W215 has 3 fuse boxes, 2 in engine bay - aft Left and Right, and one under the rear offside seat.
