2003 SL500 R230 - Dipped Headlamp Fault
kevh
Sheffield
SL500 (R230) 2003 4966cc
Can anyone please suggest a solution to my problem. - I have an intermittent issue with my Left dipped headlight. There are times when them the lamp does not illuminate when switched on, and I also get a fault message on the multi function display. In the past this has eventually rectified itself without any intervention whatsoever. My problem is that the car is booked in for MOT on Thursday 24th May, so I need to make sure that the lamp works. The car has bi-xenons (option 618).
EmilysDad
Bury Lancs
ML350
Could be the 'bulb' or the ballast, though bulbs tend to go gradually & turn pink first.
Craiglxviii
Cambs UK
Classic ballast failure...
star
Reading
Smart + others :)
Or N/s front sam?
K
kevh
Sheffield
Thanks Guys,
Where can i find the ballast and is it easy enough to replace. An idea of cost would be useful. What is sam?
EmilysDad
Bury Lancs
ML350
Thanks Guys,
SAM .... Signal Acquisition Module ... an expensive box of electrickery :eek:
star
Reading
Smart + others :)
Thanks Guys,
Guessing is not a good idea with fault finding.
John Laidlaw
Wirral
Land Rover Discovery 4
Ns front Sam was my first thought......seeing as I had that issue on mine too...corroded fuse box didn’t help either
K
kevh
Sheffield
Guys,
SAM sounds expensive - can anyone give me an idea of cost?
I'm going to go down the cheaper route by replacing the ballast. Can anyone advise me how I find the ballast/how to replace it and how much its likely to cost me. Thanks
EmilysDad
Bury Lancs
ML350
Guys,
The ballast is what powers tho bulb, so follow the wir8ng back. Swap the ballasts over & see if the fault moves.
00slk
Cambridgeshire UK
Good call to try the right hand ballast first, if they are like my Laguna and Jag the ballast's were under the headlight.
Renault cost £388, Jag was £275, needless to say I purchased to S/H ones for £88. I know not much help for you but Mercedes parts will be priced a bit more :rolleyes:
John Laidlaw
Wirral
Guys,
My SAM IIRC was c£300 (going back a couple of years and don’t have the files any more!), obviously plus labour to fit if you don’t do it yourself. I was pleasantly surprised when it did not need coded on Star
Tel: 020 8863 9233
