2004 Mercedes w220 electrical fault
Musa
W220
Hi I took my car to the mechanic so he can change the turbo when I picked it up it has many electrical problems
1. Driver-side window and seat does not work
2. Passenger-side window only works on the passenger side
3. All rear windows do not open
4. Seems like there is a drain on the battery has a charge it fully and then put it in the car and then it is Dead again
Very kind RAC Man came out and had a look did a diagnostic check and there was no electrical faults showing except a/c rad fan
If anyone can help it would be much appreciated thanks
Would be strange for the battery to drain immediately like that, are you sure the battery is holding a charge at all?
Musa
W220
Hi thanks for the response much appreciated no it doesn't rain straight away
I bought a brand-new battery as well to make sure it wasn't the battery
Musa
W220
Hi I might of found the problem I have found some high amp fuses under the foot brake pedal that are blown
