lincolnshirelad
- Nov 8, 2014
- Location
- Lincolnshire
- 2004 (W203) C180 Avantagarde Kompressor
Afternoon All,
First post on here so please go gently with my two (maybe related) issues.
I've had my MB for 2 years. It's a W203 with a 271 engine and has done 75,000 miles, been regularly serviced by an independent MB dealer and only just had an MOT. Aside from a new rear screen 2 years ago, due to radio interference with the HRW on, she's not given me much trouble.
I had a Parrot Mki 9200 and UNIKA fitted professionally a couple of months ago and the interference came back (Parrot works fine). I took it back to the auto-electrician who removed the radio/Parrot, inspected and tested everything (checking and replacing fuses, etc) but couldn't fix the fault - even by setting the radio electrics back to standard. The amplifier is fine as there wasn't any sound when the fuse was pulled. The HRW is doing it's job too. Could it be the SOT lead? It's a SOT-976 fitted.
Then on starting the car up the Engine Management Light came on. Driving home I noticed a lack of power when initially accelerating/on kick-down though the car will do 60mph without any issue.
The auto-electrician had a look at the car with his diagnostics and the following DTCs were thrown up:
P0445 - Evaporative Emission System Purge Control Valve circuit shorted
P0365 - Camshaft Position Sensor B circuit (Bank 1)
P0031 - HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
P0037 - HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
P0075 - Intake Valve Control Circuit (Bank 1)
On one occasion I still had 5 DTCs but P0445 and P0075 were replaced by P0010 and P0020.
You can clear the DTCs and Engine Management light with the ignition off and have 'no DTCs found' and drive her fine, but when you stop the car and start her up again the light and DTCs come back.
Live data with the car at idle as follows:
Fuel System: OL-FAU
Fuel System 2: Not used
Load Valve: 13.7
Coolant Temp: 73
Short Term FT: 0
Long Term FT: 0
Intake MAP: 34
Eng RPM: 730
Ign Adv: 10
Vehicle Speed: 0
Intake Air: 23
Airflow MAF: 0.00 (even with car revving at 3000rpm??)
Throttle Position: 3.1
Sec Air: Not used
O2 2 Bank : 0.435
Distance with MIL: 0
Wide O2 (S1 B1): 1.498
I've read on here that the Engine Management light can be for a variety of reasons e.g. loose/split breather pipe/vent hose, blocked oil breather, oil in wiring loom, LAMDA sensor, fouled plugs, MAF...Does this sound like an ignition problem (short circuit DTCs) rather than a fuel injection or exhaust system issue?
The auto-electrician is stumped on the interference as he's not changed anything to do with the HRW/Amplifier on visit 1 and even after re-inspecting her on visit 2 he's not tinkered with anything to do with the ECM.
I'm stumped as before the parrot installation the HRW and radio worked fine together for 2 years with no interference and the car has run 100% tip-top until after the second visit.I've never had the Engine Management light come on before. Service B is due on 1000 miles and there are 'no malfunctions' on the screen.
Any help and suggestions are gratefully received.
Thanks again.
LL
Fuel System: OL-FAU
Load Valve: 13.7
Coolant Temp: 73
Short Term FT: 0
Long Term FT: 0
Intake MAP: 34
Eng RPM: 730
Ign Adv: 10
Vehicle Speed: 0
Intake Air: 23
Sec Air: Not used
O2 2 Bank : 0.435
Thanks again.
LL
