2005 CLK windscreen wiper arm
Grotbag
London
2015 C220 Estate Sport Premium AND 2005 CLK 200K Convertible Avantgarde
Hi all
Slight problem with my CLK
The passenger side windscreen wiper isn't working. Driver side OK
The arm feels like it's not connected to anything. It is loose and floppy.
Either it has disconnected itself or something has snapped.
Any ideas if it's an easy fix for a complete novice or is it a trip to my Indy.
Thanks all
Craiglxviii
Cambs UK
Both wiper arms off (one nut each); windscreen plastic scuttle off.
Underneath is a motor (driver's side) with an arrangement of linked steel tube arms that translate the movement to the wiper spindle at the passenger side. There's not much to break really, it's all pretty damn solid!
Do check that the wiper arm is not loose on its spline, was the blade frozen to the glass when started.
Grotbag
Grotbag
London
Hi Television
Yes it was frozen last night.
Is it easy to put back?
Craiglxviii
Cambs UK
Unscrew the nut holding the arm on, remove the arm, cycle the wiper blades once, turn engine off then refit the wiper blade in the horizontal position. Dead easy.
Grotbag
Grotbag
London
Thanks Craig, My Indy said exactly the same and he is going to show me how to do it in the morning as I'm useless!!!
No one is useless ;)
Grotbag
Grotbag
London
Hopefully after tomorrow morning I will be a skilled
'frozen windscreen wiper arm fixer'
Craiglxviii
Cambs UK
Do you have a toolkit? A socket set..?
All you need to do is to prise off the plastic cap and then with the arm in the correct place tighten up the nut under the cap.
Grotbag
Grotbag
London
Craig, I know what you are going to tell me. My Indy will show me tomorrow and probably won't charge :)
Grotbag
Grotbag
London
All done.. Thanks for all your advice. Simply needed the 2 screws tightened.
No charge and I know how to do it next time.
Thanks again everyone
I am pleased that you can now see what you might hit now, good one.
Craiglxviii
Cambs UK
No you don't... I was asking if you had a tool set, do you?
