2007 ML - Poltergeists!!!
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by Sallyday10, Mar 20, 2017.
  1. Sallyday10
    Sallyday10 Member
    15
    Nov 2, 2016
    Cheshire
    Your Mercedes:
    C-Class 2007 2.1 Diesel Sport Auto
    My pal has an ML that has started behaving badly recently.
    Problems include alarm triggering apparently by itself, wipers activating by themselves, problems with interior lights, dashboard 'lighting up' and other such intermittent electrical problems.
    Any clues?
    Is there a control unit for this lot located in the floor pan somewhere?
    Do these cars suffer from blocked drain tubes which can lead to water ingress causing damage to circuitry somewhere?
    Any help would be much appreciated,
    Thanks.
  2. Taffy7hfa
    Taffy7hfa Senior Member
    475
    22
    May 29, 2016
    Oxford
    Your Mercedes:
    Mercedes ML w163,270CDI, 2002,Comand,Parktronic,Memory seats,Family pack,Tiptronic.
    Has it been pressure washed/steam cleaned recently? are the carpets damp ? does the glass get steamed up easily?
  3. OP
    Sallyday10
    Sallyday10 Member
    15
    Nov 2, 2016
    Cheshire
    Your Mercedes:
    None of those, but on the day it all started, it had been raining very heavily.
  4. Mark A
    Mark A Senior Member
    720
    8
    Aug 13, 2006
    Aberdeen
    Your Mercedes:
    08 ML-420CDI, 58 ML-320CDI, 55 SLK-350
    Check in the boot, drivers side access panel. There is a fuse box directly ahead, but the culprit could be the rear SAM (Signal Aquisition Module), which is lower down and sits below the boot floor level. This can get wet through either failure of the seal around the light or the seal on the 3rd brake light.
    I had months of problems until the garage believed me and changed the SAM.
    The seal is about £20 and the brake light about £60 IIRC.
    Mark
  5. OP
    Sallyday10
    Sallyday10 Member
    15
    Nov 2, 2016
    Cheshire
    Your Mercedes:
    Hi Mark,
    thanks for the guidance - I'll check the seal around the 3rd, high-level brake light, but what's the other seal you refer to please?
    Many thanks once again.
  6. Mark A
    720
    8
    Aug 13, 2006
    Aberdeen
    Your Mercedes:
    Drivers side rear light cluster. There are 2 seals on it. Supplied together.
    Pretty simple to change.
  7. Xtractorfan
    Xtractorfan Senior Member
    5,981
    115
    Nov 16, 2007
    Your Mercedes:
    S class
    You may be able to get someone to disconnect the battery..under the drivers seat.. and remove the rear sam and fuse box and blow dry them with a hair dryer and they should work perfectly.
Share This Page
