2013 ML350 Diesel oil cooler seal leak
silkthread
2013 ML350 diesel
Hi all,
Just found the oil cooler leaking oil and also some rust coming through on the sump and need to find somewhere to do the seals, new sump and a fuel hose (that has a small split) - a pain in the butt job on labour hours after taking apart the manifold, turbo, etc just to get to the oil cooler! Can anyone recommend a trustworthy garage near the Spelthorne Surrey area?
Many thanks,
AMGeed
Poole, Dorset
S204 C180K
Hi all,
Many thanks,
It's a bit of a run down the A3 to Horndean, but Olly at PCS is an excellent Mercedes specialist and may be able to offer an courtesy car whilst yours is being repaired.
I did reply to your other thread so you now have a recommendation for a good Mercedes indy.
silkthread
silkthread
2013 ML350 diesel
Thank you very much for the suggestion - I don't mind a drive for someone trustworthy! I'll give him a call in the morning :)
