2014 C220d W204 Automatic Transmission Leak
Maidment78
New Registration
C220 Estate 2014
Evening all,
I have developed a leak and need to sort it, I have been able to ID the cooler but I think the pipes have seen better days but I can now work out what I need. Oil is pooling on top of the cooler then dumping on the drive after a long run.
Does anyone know the part numbers?
I am hoping the rad is ok but at least I know what that is if needed.
Thank you in advance.
Take a trip to a MB dealers and order them and clips.
Nala100
Registered
C220 CDI 2007 W204
Evening all,
Hi Maidment78
I had exactly the same problem. 2014 E 250 Cabrio W207 OM651 7G Plus transmission. 28000 miles .Parts required, A 0009973363 Coupler 2 of approx £4 each from LLL Parts online. These are quick connect transmission line connectors made by Oetiker for Mercedes. There are several technical drawings online to show the o ring layout. Transmission Oil Cooler A 0995001100 good quality pattern part approx £60 available from many suppliers online, 1 Litre Transmission Fluid, 1 Litre Coolant, both genuine Mercedes. Local garage charged 2 hours labour including on ramp transmission top up and road test. Problem solved.
