2015 Vito 114 CDI / 2.1L engine - Limp mode
zed_raz
Hope someone can guide me or take this job.
Have a 2015 Vito 114CDI, was initially making a rather loud hissing/whistle turbo noise when accelerating. Now that's all stopped, engine management lights on the dash and it's in limp mode.
I've scanned and got the following error codes.
P0299 Turbocharger/Supercharger 'A' Underboost Condition
P2261 Turbocharger/Supercharger Bypass Valve 'A' - Mechanical
Also see attached, found signs of oil? underneath and on a metal clip holding a pipe.
Hope someone can anyone guide on what needs to be done/checked please?
Kev555
N.I
looks like that clip on the boost pipe is broke or came apart from photo 2. Also damage to that steel crossmember or subframe that also looks to have broke that clip at least and possibly damaged pipe or intercooler plastic. wonder if it was trolley jack damage or off road damage? Looks like you have an idea where to look when you found that, Good find.
ajlsl600
france
Suspect boost leak is giving fault codes. Check that out
VitoVanMan
Amber Valley
Vito 2005 115 CDI W639, Saab 93 TiD
Do you go into limp mode as soon as you pull away and hit 2000rpm?
