230CE problems
Status
Not open for further replies.
Mark Raynor
London
Can anyone help I have a 230CE 1985 and if I take a deep right turn I get a loud noise from the back left wheel area I have been told it may be the rear axle I would appreciate any thoughts before I fork out £500.
cheers
Mark
Andy
West Midlands
www.mercedesservicing.com
Hi Mark,
Before forking out the money. Double check the rear axle shafts CV joint. Usually you can actually see the marks in the casing caused by the ball bearings rolling where they shouldn't. Also make  sure the wheel bearings are in good order & no excessive play. You could remove the back plate of the diff and have a look. If the noise is that bad. There should be some evidence of debris.
Regards
Andy @www.mercedesservicing.com
PS, Take a trip to the midlands & lets have a look. Good luck!
M
Mark Raynor
London
Cheers Andy
I'll have a go at the weekend and see what I can see.
Mark
Ian Waterhouse
Had very similar noise.  After some investigation it was the mud-flap hanging too low and bouncing on the road.
This sounded for all the world like a badly worn C.V. joint
Status
www.W140.co.uk&www.r129.co
