410D Steering box
gpb
I have a 1990 410D with fairly sloppy steering, probably a feature I know but I'd like to minimise the play in the steering box if possible, anybody got any info on this ?
Do you have power steering or manual
G
gpb
It has power steering.
I've looked at adjusting the backlash but not sure which way to turn the screw, have read that some adjust oposite way to what you might expect ?
This is complicated for owing to the chassis variants, there is nothing in the commercial section that deals with this.
I am not sure if the van has a car type steering box, the VIN number might help sort this.
On the car type boxes, the nut on the end of the box is turned anti clock to take up the play. There are dangers here in the if over tightened the wheel can stick or jam when turned onto full lock.
With car type steering 20 mm is allowed at the steering wheel, but 30mm on commercial boxes.
With the first 6 VIN number I might be able to offer more info
G
gpb
Vin no. is WDB6114181P099326
G
gpb
Television, don't leave me now....
All I have is how to check any play, nothing there for the steering box its all on microfiche.
I have printed off the only paper there is and you can have that if you wish.
I can give you the data and info on a car box from the same vintage, but I do not know if its the same.
Cosworth
The power steering on these vans have a similar design to the car steering box. But they both look different and are not the same.
Sounds like your steering box is got a lot of play in it.
I will check with my dad as he bought a steering box about 6 years ago to do a conversion on his van. The steering bos has low miles on it. I will see+ if he still has it or not.
G
gpb
Thanks guys
power-steering
Greenwich, South-East London
We can do a simple test & adjust for you, very affordable. Can do full remanufacture or even just a simple test & adjust to eliminate play.
Give us a call on 0208 853 3343 and we'll advise you on best route.
Cheers,
Jay
