cellardoor
So far i can see there is a lot of old oil and dirt on the accelerator links, I will clean those up first. Then i will dismantle intake system looking for an airflow meter-perhaps it is dirty or malfunctioning and can be repaired. Or reset?
Anyone been there already? What did you find, what did you do, did it work??? Also the auto box will not kick down properly, it is a bit sluggish. I am hoping it can be adjusted via the accelerator-transmission connections. Although I do realise it has an electricall kickdown switch under the gas pedal.
