A few small jobs for the weekend.
SmartAmg
SmartAmg
2011 E class coupe 350 CDI
  • #22
Where did you get the V6 stickers ?
Had them made at a graphic/sticker company in St Helens, they scanned a template that i did. Now i know they look good i might get some 5mm red perspex ones done, think they will look good slightly raised from the engine cover .
DREAMER NO2
W124 2.6E M103 1989
Smart AMG Can i give word of warning .The locking wheel nuts with the snail imprint in are poor .You need to change them for a better set . The locking key is made os softer material than the nuts and it gives way just when your stuck with a flat tyre on the motorway . Ask me why i know ..
SmartAmg
SmartAmg
  • #24
Ok, thanks for the heads up.
By the way how do you know?
DREAMER NO2
W124 2.6E M103 1989
Reason i know is the same set was fitted to my Volvo v70 .And i was stranded on the motorway unable to remove the rear wheel.Thats how i know .Even a video on youtube on the very same locking wheel nuts ,check it out.
SmartAmg
SmartAmg
  • #27
Ok, will do.
SmartAmg
SmartAmg
  • #29
Are pressed metal plates legal on modern cars??
Yep, if done with the correct font and spaced correctly. There are companies that will make you legal metal pressed plates.
JBell
Torquey
C350 CDi Estate (GAD Edition)
Agreed, mine have the manufacturers postcode and are BSAU stamped which is what you need
AnthonyUK
Alton, Hants
C240 estate 2002
Thanks. I read some conflicting info so didn’t want to ‘waste’ money.
DREAMER NO2
W124 2.6E M103 1989
..My plates are original and were fitted by the dealer back in 1989 by Carols of Wolverhampton.But i did change the plate holder after one of the number plate screw fixings broke off. So the older owners take care, the brass screws dont like being removed ,they shear off first .,
JBell
Torquey
The ones I posted are totally road legal, they are from a DVAL registered supplier.
