Carlitos
- Sep 14, 2013
- Location
- Poole, Dorset
- C200K Coupe 203
Hi all... Thought I'd share a little project of mine. Might turn out good... might not. But the learning process is fun.
Decided to up the output from the supercharger. Managed to source a smaller pulley from Poland, a guy over there makes pulleys for various SC's. So the idea is that a smaller pulley on the supercharger means higher boost from the supercharger.This will mean the SC works harder (more rpm), more forced air (hotter) and higher SC rotor speeds particularly at high rpm (more hotter again).
So smaller pulley = more power. Great! But my concern is heat. The extra air means more friction and more heat. So to compensate I decided to port & polish the supercharger & inlet/outlet. Idea being the smooth it is the less air drag happens and less heat builds up. Hopefully compensating for the extra boost I'll be making.
I don't want to mess my own SC up so I bought one off ebay for £110. Bargain! You might be able to see in some of the early pictures how coarse the internal casting of the SC housing is. The more coarse, the more friction.. the more heat.
The SC without the inlet/outlet metal part
Size difference btweeen old & new pulley.
Started to port the inlet/outlet part
Let's get that old pulley off..... it's a bit tight!
Had to cut it and then heat it to removed even with the pulling kit. Was quite seized on. Although I should also say the new pulley was too loose. I contacted the chap in Poland who is sending another one out to me. So I'll continue with until that arrives.
Cut back the snout so the new pulley has more freedom to fit
Remove the screws. Note that the oil plug screw is damaged. I couldn't get that thing to budge and now it's worn down so decided to leave it how it is and change the oil later.
Needle bearing seem to be ok so have to sseal them off... don't want dirt getting int.
Oil... stinky
Back of snout
Porting in progress. I live in a flat so the safest place for me to do this is actually in the bathroom (I don't have outside areas to do this). Decent breathing filter and eye glasses are definitely required! Safety first. The tool I use is a rotary tool from Maplins, a cheap Dremmel. I have an extention and various tools, mostly sanding sleeves.
In progress but still not finished.
Oil... stinky
Back of snout
