A150 Intermittent start fault
jrb1976
New Registration
A class 150 '06
My '06 A150 has developed an intermittent start fault. When I insert the key I hear it unlock the steering column with a shuffling noise but on turning the key there is just a click (although engine lights, radio etc all come on).
Sometimes if I remove the key and repeat process several times, it will start but at the weekend this simple strategy failed. If my journey is simply from A to B it will starts ok but if journey is A - B, B - C, C - D in other words after short journeys with multiple stops then i have a problem. On Saturday the car refused to start again after having driven 12 miles. After a 4 hour 'rest' it started first time. Obviously this is very disconcerting and potentially dangerous.
Using the spare key makes no difference - so I suspect it is a transponder/immobiliser problem. I am about to contact MB main dealer but browsing the forum, it seems other owners have experienced similar difficulties in the past. I would appreciate hearing from anyone who has any news, advice, recommendations etc - especially whether it might be a known Mercedes fault for which they acknowledge responsibility - i live in hope!
(BTW: The car is well serviced, low mileage 23500). Thank you.
A
andy@pcd-ltd
if you are getting a click when trying to start it i would say it is more than likely the starter motor is on its way out, as if it were a immobiliser fault you wouldnt even get a click from the starter..
N
nursegeeza
a150 fault
hi i have the same problem ...what did it turn out to be in your case??
MissyD
Essex init
www.depop.com
E200 1993, E300 Coupe 2019
Welcome nursegeeza, interesting username. Unfortunately the OP hasnt posted since the initial post in April, so we dont know the outcome, but like Andy @ pcd posted, likely the starter motor is on its way out. Maybe you can let us know how you get on.
spongy
New Registration
hampshire
sprinter motorhome
I have the same problem with my sprinter motorhome, main dealer has replaced the fuse board and relays, fitted a new ignition unit but the problem is still there. Dealer said 1st that starter motor was ok but I am beginning to think they have'nt a clue. So far I have spent over £1100 with no result.
spongy
