Lowe712131
- Jan 21, 2014
- Location
- Midlands, UK
- R230 SL500 / Aston Martin DB9 Volante
Hi all - have got some major work planned on the ABC system on my SL55 - valve block overhaul (x2), new accumulators, 1 x level sensor, fluid, filter etc.. but the only item I'm not (currently!) replacing is the Pressure Relief valve block. One of the symptoms I'm getting is an occasional 'jumpiness' when sitting at traffic lights etc - not as bad as a rodeo, but just small movements in the struts when I come to a stop - to me, that sounds system pressure related? Any thoughts? Pump is good and pressure at standstill seems pretty constant, around 190bar.
Also, I will be buying a job lot of O-rings for the ABC valve block job, so if anyone else needs some, I will be able to put a few sets together. Watch this space.
Simon
Simon
